A AC Question May 5, 2017 #1 I had it in UPSM, the battery completely died and it went off. When I plugged it back in, it says "turning off UPSM" but then it stays gray. Can you give me steps to correct?
B. Diddy Senior Ambassador Moderator Mar 9, 2012 168,936 10,037 113 May 9, 2017 #2 Welcome to Android Central! Try powering off first, and then charge it until the battery is 100%. Then power back on. Does the problem go away?
