My GS3 Mount Mod for PS3 Controller.
Gerane
Active member
May 17, 2010
29
I wanted to make a mount mod to play games on my GS3 using a Sixaxis PS3 controller. Here are some pictures of how I made it. All parts were inexpensive and only one that is a little difficult to find was the plastic piece that I built my mount around. I bought a cheap 10 dollar or so PS3 wireless keyboard and used its mount for this. I will be using the keyboard with my old phone as a XBMC project with HDMI cord. So in the end the clip was a bonus.
Could you do that with an xbox controller? Also how do you even connect it to your ps3 controller?
The ps3 controller connects via Bluetooth and is configured using an app called sixaxis controller.
The Xbox controllers don't use Bluetooth.
The mount has different tilt settings. So I can adjust it depending on my needs
Sent from my SCH-I535 using Android Central Forums
You could use the USB to go feature and used a wired ps3 or xbox 360. The ps3 runs natively but the 360 requires and app available in the market. Very cool design, I bet you could sell a bunch of those.
I think it would be harder to mount a phone to a Xbox controller.
I am really enjoying it so far. I am impressed at how well the joystick movement works.
Wow great job man. Just a request, could you list the pieces and where you purchased. I would like to make one if these myself.
I would love a parts list as well.
Looks like the plastic keyboard mount would work wonderfully.
I will try to get a list together this weekend of the parts and where I bought them.
Haven't had a chance to yet. An going to tomorrow though.
That's a awesome mod man :)
Thanks man looked for the cheap keyboard mount and could not find it. Is an awesome mod
Where can i get the clear plastic clip that holds the ps3 controller? you could send me a full parts list as I'm deffo going to make one of these... it looks awesome :)
Sandra dewei
