My HTC Stuck on White Screen
And it still popped up the error? Hmm...well, do you put it in Fastboot yourself or do you let the RUU do it?
all u need to do is restart your phone by holding the power button then a list should come up and a restart option should be there
So my Htc vivid is stuck when i turn it on , it stays on htc ._. what do i do ? need Info Asap
Hi, I have the same issue with my htc vivid going to the white htc screen. I had it on wcx rom but wanted something a lil different so i went to flash holics rom on it but it had an issue with the wifi so i tried to fastboot flash the image but to no avail. o i reflashed the the wcx rom and the ics gapps but now when it reboots it stays stuck on white screen. i wiped all data and reflashed many times but still nothing. then i tried to flash the stock RUU but it tries to load then gives an error message about error on signature. now i am at wits end and asking for help. I haven't flashed a rom on this phone in a long time so i am rusty. did i miss something?
On WCX ROM, you don't need to flash Gapps. And you flashed the "boot.img" before and after you flashed the HOLLICS ROM?
As for running/executing the RUU, your bootloader must be locked and you must be S-ON for it to work.
Sent from my HTC Vivid BoRKed using Android Central Forums
Hello All,
I have a similar issue as on this thread and after thorough investigation and countless nights looking for a solution i finally broke down enough to ask for help. I have an issue with my rooted HTC Vivid not able to load my original custom wcx rom back on, i was bored of it so i tried flashing holics rom on it but the wifi did not work so i tried to reflash wcx back and now i am stuck between bootloader and HTC white screen loop. Now it has the issue of "HBOOT, Main Version is older! Update Fail! I have relentlessly searched for a compatible boot.img but to no avail. I am at my witts end, i did this customization about a year and a half ago so i am a lil rusty. Please help!!!!
Did you just ignore me? I asked you some questions, hoping for a response. I'm trying to help you with your issue, but you won't work with me, pal.
pututo
