My Huawei y336 u02 doesn't go beyond android system recovery even after wiping and wiping
  • Start date Start date
A
Android Central Question
My Huawei phone's got a problem I don't understand.
Whenever I switch it on the normal way, it vibrates the comes on. After showing the logo, it goes off and comes on by itself only to go to "Android recovery mode". I wiped data/factory reset, wiped cache partition, and each time I try applying update from external storage, from ADB, Cache or perform system partition check, It shows "root check failed ori... device has been root! Installation aborted", pls, how do I get out of this?
crayzeefoo
