My Moto G5s plus battery is draining too fast.
  • Start date Start date
A
Android Central Question
My Moto g5s plus phone's battery is dying in just 5-6 hours whether I use it or not.
I've reset the phone but still the problem continues. It just started at once, it was working fine and a next day the problem started.
What do your battery usage stats indicate as having used the charge after such a drain?
I recommend registering as a member so that you can post screenshots.
Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
Also, see if the battery drains like that in Safe Mode: https://motorola-global-portal.custhelp.com/app/answers/indevice_detail/a_id/116299/p/30,6720,10165
asnes
