My Moto G6 Plus fails to discover my headset
  • Start date Start date
A
Android Central Question
My Moto G6 Plus is no longer showing my wireless earbuds. It did once.
I have done multiple things, nothing has worked so far. And I don't know what else to do.
I was able to use the headset with the desktop pc last night without a problem.
I did remove the headset's info from the pc just in case, and turned it off too while I tried pairing with the phone.
The earbuds are Sound Hub XD2 from iFrogz.
Any ideas will be greatly appreciated.
Thanks
Ooh! Never mind, I was mistaking Reset app prefs with "Reset Wi-Fi, mobile & bluetooth"... Besides it says at the bottom: You will not loose any app data!
I guess I should try
Oooh!
You won't believe it!
In the "Connected devices" page is a clickable text saying: "Previously connected devices". For some reason this info survived the 2 resets, both of the Bluetooth data and the apps prefs. So it opened a new page with a list of all previously connected devices, among them is my new headset. I just clicked there 2 seconds after I turned the headset on, and voila!!!!
Geez!! That was some experience.
I appreciate your patience and perseverance guys! Kudos to both of you! :)
Thanks a lot
Nazeer zaheen
