My phone wont turn on. Help please D; lg optimus s
klokateer123
240
I had recently rooted my phone, then i deleted stock apps and the power on/off sound. im not sure if this is important but i went through all my phones root files just to see what was on it (i was bored). i also installed titanium back up and rom manager then uninstalled rom manger after knowing that it didnt support lg optimus s. then i was going to use gameboid but then every time i opened the app it force closed. so i decided to turn my phone off and when i turned it on it wouldnt go past the android screen.
Your help is appreciated :)
I'm not suggesting you install ZVH. I am suggesting you do factory reset, which is the same for ZVD, ZVH, etc.
If you are on Xionia or some other recovery, just adjust to their menus and do the same factory reset.
You'll lose your data, but you should get the phone booting again.
I tried to factory reset my phone using the stock recovery, but it didnt seem to do much good. it just kinda delayed the time the android screen blinks :/.
Then the "bad" think you did is not in your /data and is somewhere else.
Can you force a boot into recovery? Disconnect USB, pull battery, reinsert battery/cover, press AND hold [Power][VolDwn][Home] until recovery shows up, then release buttons
If you can do that, apply the ZVD full update
http://forums.androidcentral.com/lg...sprint-zvd-froyo-downgrade-now-available.html
When that is done, if things still aren't working quite right, perform a ##786# reset from the dialer. You'll need your MSL code from Sprint.
You could also apply the ZVH update or apply it after the ZVD update. ZVD is a more complete update so I'm suggesting that first.
What if I cant get into recovery? I did a factory reset, the phone rebooted. It sayd its resetting, then it goes into infinite bootloop. Now, if I just turn it on it goes to LG screen. If I try to go to recovery, it shows the reseting to factory.
I have the same problem, I installed a font app (root needed) and I download a font, but my L5 E610 turn off and it goes to a infinitive bootloop, I tried the Hard Reset but it stops and restart the device and goes again to a infinitive bootloop! Ahhhhhhh... Someone can help me? If you now some thing to consert it tell me/us! I don't have more any cell phone to use :((((
Wait if you can still get into recovery just flash a rom
Sent from my VM670 using Tapatalk 2
Just boot into recovery using the key combo and restore your nandroid backup. ;)
Also, no clue what a "L5 E610" is, so please go to the appropriate forum thread for help with that.
Tdoperfdu
