My Photon allergic to Go Launcher
Been using Go Launcher with my MoPho for over a month with none of the issues described. The only Go Widget I use is Twitter posting.
Double checking, but you guys are using Go Launcher EX, right?
I'm using Go Launcher EX and occasionally my phone won't open any apps and then the home screen would reset indefinitely; very annoying indeed. I haven't tried Launcher Pro since I like to hide unneeded apps in my App Launcher with Go Launcher.
Launcher Pro can't hide apps in the app drawer? I thought I heard it could do that. I'll be trying LPP this week.
Thanks all, for the insights. I've been wondering which ones to consider and you've given me some good food for thought.
Okay, so LauncherPro DOES let you hide apps in the App Launcher but DOESN'T let you create folders in the App Launcher.
I tried Go Launcher EX and now I want to go back to my Moto original launcher, but I can not get rid of Go Launcher. It has inserted itself as a non-removable app.
How did you remove it or is you just install LauncherPro over it.
I just really want to go back to where I was but if I can not then I will try LauncherPro app.
Main question is how did you get rid of Go Launcher EX and its little friends?
Find Golauncher in the app drawer. Tap and hold. It will shack like the iphone apps. Tap the X to uninstall. Restart phone to make sure the Moto Blur is back.
Go Launcher is not very good. I dont know but for some reason the best Launcher I have used is the Xperia S launcher. The icons were smooth, everything was fast and responsive and it just felt natural
oval_clarity
