MY S4 Keeps freezing help please :(
Charlene1991
Active member
Apr 30, 2013
43
Basically, every 2-3 minutes my screen freezes for 2-5 seconds. It happens every time. For example, when I watch a video on YouTube, the screen freezes but the sound still plays and another example, On twitter I read comments, I scroll down then it freezes for 2-5 seconds. I have the latest update etc. Please does anyone know how to fix this? I tried restarting phone and turning of and on. Can someone help me please? Really appreciated. :)
Thank you
I got rid of my s4 because I didn't like the new update.
Did you notice it before any New apps were installed? May have to FDR and see what that does.
Sent from my LG-D801 using AC Forums mobile app
I'm not sure if it's the update that made my phone freeze or apps, but is there a way to restart my phone? like how do you erase everything but NOT my phone contacts? will that solve the problem you think? if yes how do I do that?
Just make sure you sync your contacts and then do a factory data reset.
You can turn phone off. Hold volume up + home button + power button until recovery mode pops up, then choose wipe cache partition and see if that helps. If not, then go back into recovery and choose wipe data/factory reset.
modsmelon
