My S6 Edge won't power back on after resetting it, what can I do?
  • Start date Start date
A
AC Question
My phone was working perfectly fine this morning when I got up. I went to make a call, it wouldn't connect so I went to Restart it, it froze on the "Starting Apps" screen. I did the whole "Holding the volume & Power" It powers up like it should, but doesn't move past the Samsung S6 Edge Screen. The blue light is flickering on it also. I don't know what to do!!!
Re: My S6 Edge won't power back on after resetting it
Boot into recovery and clear dalvik cache and cache then reboot
Press and hold all 4 physical buttons at the same time until it resets. Should be a few seconds.
I've been doing that for 2 hours and it just powers on the Samsung S6 Edge Screen, then goes black & the blue light blinks... I don't know what else to try!:(
how do i do that? The screen won't come on at all except when the Samsung S6 Edge start up come on. then it just shuts back off.
Ok so if you have tried holding both vol buttons and the home button and the power at the same time and that doesn't help, then try get to recovery by holding the volume up and home buttons simultaneously and then powering on the phone. Keep the vol and home keys in until it goes to the recovery. Hopefully. If you get there, try clearing the cache and then reboot
Tired it.. nothing happened. Screen just stayed black. =/ =(
Can't boot my phone
It just randomly shut off this morning. I've done a master reset, tried the whole ODIN thing... It gets to the "Android Starting Apps" screen, but won't move from there. Now I can't get it to even get to that screen.. It's a Samsung S6 Edge. I've read for hours that this is a common issue but they all corrected it by simply rebooting their phones... it hasn't worked for me. The phone is on & charged. There's a blue LED light blinking. It vibrates randomly. It has to be a software issue. Does anyone know how to fix it?
Merged a couple of threads. When you say you tried the whole Odin thing, do you mean that you were just trying to get into the Recovery Menu to wipe the cache or do a factory reset (which is not the same as Odin mode), or did you actually use Odin to try to reinstall the firmware? http://forums.androidcentral.com/am...w-flash-stock-rom-via-odin-new-interface.html
