My Wifi Wont connect need help.
jrgonz454
Active member
Nov 10, 2009
26
Seems that every so often my VZW Tab wont connect to my WIFI. Every other device connects well. The only fix Ive found was doing a wipe, but thats a pain in the ass. Any suggestions.
You are not alone - this is a widely known problem with the GT. So far the only fix that seems to work consistently is the hard reset to factory settings. There's a lengthy discussion about this at Android Forums.
I found that my galaxy tab will not stay connected to g routers, but when i switched to an N router, it works fine..same thing happened to my friend and we do not live in the same area..
Jayarealways
