Mysteriously added contact to home screen
mustang:
Searching "administrator" in settings, I get "Security - Device admin apps - view or turn off device administrators.
That arrow is the pull-down tray. 1 finger: some apps (I don't know how they get there), 2 fingers: on/off for wi-fi, airplane mode, location, do not disturb, etc.
B. Diddy: that link does not show how to do that...
mustang:
You just see find my phone in Device Administrator? That's fine if so
That arrow is not stock so something has been downloaded and preventing your ability to change those 2 widgets
That arrow has been there since I got the phone from my FIL two months ago. The stuck widgets appeared less than a week ago.
Something is changed there from stock , you have lot of apps ? If you can't pinpoint what's installed , I recommend start fresh with factory reset
Um. Maybe I should have mentioned that this cell phone is probably considered ancient, by most people's standards today? It's a Samsung Galaxy J3 running Oreo. Does that change things? Sorry.
B. Diddy: I wiped the cache partition. Same.
It is getting old that android version , but like i mentioned factory reset should be next step
That first screenshot looks like it's from a 3rd party app, don't you think, @mustang7757? Since this doesn't go away in Safe Mode, I wonder if the phone might have been rooted, with a custom ROM installed?
Yeah definitely something downloaded, i thought a launcher or 3rd party app, can go to settings >about phone>status and see of phone status says official , and why i mentioned factory reset.
...settings >about phone>status and see of phone status says official...
"Device status?" Says "Official....
When you got the phone from your father-in-law, did you do a full factory reset at the time? It's usually a good idea to do that whenever transferring the phone from one person to another, even if it's a family member.
Thats what ive been saying
dunalfu2
