Nav Star broke Edge Panel
Samsmome
270
When I have nav Star enabled, my edge panel doesn't work. When it's not enabled, edge panel works just fine. Hmm 🤔
Anyone else have problems???
Navstar is working now? I just tried it and it still doesn't work since the One UI 2.0 update.
That's what it is. I didn't realize he or she said they were on 2.0. it won't work until the 2.1 update.
I got the update to 2.1 yesterday morning.
I like to use the cat icons on the navigation bar. So when I enable it and switch to it edge panel won't pull out.
NavStar is working again after 2.1 for me, I'm using gestures though, gotten so used to it.
I'm on Nice Lock not Good Lock but they are the same really
Ok now I see what the OP was talking about. When I first updated Navastar I didn't have the issue , but all of a sudden now I am. I really don't want to turn off Navastar. Ugh.
For me, the issue does not show up until I turn on the show / hide navigation bar function in NavStar and then Edge screen stops working. If you want to turn NavStar on just to rearrange or change the appearance of the navigation buttons that might work, but the main reason I wanted NavStar was for the show / hide navigation bar functionality. I usually use the Samsung swipe from bottom gestures but since Task Changer broke the Google assistant gesture, I was thinking about going back to the navigation bar if there was a way to hide it. Hopefully NavStar and Task Changer both get fixed soon.
I just turned off the show/hide button and now it's working again. While I'm ok with leaving my navigation bar up all the time, I hope they fix it for those of you who use the show/hide function.
vickyy
