Need help after rooting LG G2
dustin_dej
6
I rooted my G2 (Verizon, running KitKat) I can see now SuperSU app. But it doesn't have any data. All it contains three Tabs 1:App(NoData) 2:Log(NoData) 3:Settings (have few options). What am I missing or haven't set up correctly? This is all fairly new to me so any advice would be greatly helpful to someone who's relatively new to the rooting scene.
Thanks for any helpful advice!
SuperSU will show apps that access root. For example, if you download Titanium Backup from the play store and open it, SuperSU will grant it root permissions (as TiBu requires root permissions in order to function). This access will then be logged in SuperSU. That's all the app is generally used for, logging and granting root permissions to apps that require it.
AlarmedPrize7500
