The thing is, I've heard good things about all 3 of these companies, but phantom skinz sells 2 for 8 dollars shipped. Ghost armor is 13.50 for 1. Bodyguarz is 15.00 for 1.
If you need more than one of these products over the life of your phone then they aren't worth the money. Maybe phantom skinz is just generous and wants to give away product.
Personally I've got Invisishield and love it. It does create some finger drag for the first week or two but goes away with use
i have a steinheil sgp crystal clear on my incredible, love it EXCEPT that it peels around the edges. easy install, it's a sticker, but i can't stand the peeling. does phantom skins have peeling at the edges?
also, ghost armor is like an invisible shield, right? slightly thicker, wet apply?
I only use one screen protector or shield, and that is ZAGG Invisible Shield. I have one on my Incredible and it works very well. One thing that's a bit of a pain though is that you need to let it dry. They say 24 hours. That's a lot of time to not use your phone.
Other than that, very good. I can't tell if it slows down my fingers or not...
