Need help: External USB keyboard 4 Innotech Android 4.0
espressobeanie
Hi,
I have an Innotech Innosoul Android ICS 4.0 tablet. I'm trying to find an external keyboard for it. It doesn't have Bluetooth built-in, only wireless. I've been trying to root the device, and I enabled USB debugging, but any external keyboard that I plug into the device will not work and the 3 keyboard lights will not light up when I press Caps, Num, and Scroll Lock. Does anyone have any practical suggestions on what I should look at next to get keyboard functionality on it? Any help will greatly be appreciated.
Thanks
If it's running the default ROM. Which might not be AOSP, then it may never work. Even if it is AOSP, I'm sure there's a fair bit of devices that don't work with AOSP USB host mode. I would check with the manufacturer and ask about USB host mode on that tablet. If they say it should work, try another USB keyboard(different brand etc). If they say that USB host mode doesn't work on this tablet, hope for a CM7/CM9 port.
Ty. Here's the problem. The Canadian manufacturer doesn't have a website. How can I check if it's running the default ROM?
heritagevine06
