Need help fast no data
Monkz8897
Active member
Oct 25, 2011
25
Ok my optimus s is rooted and running thundeRom-v1.8.3 and the kernal is 2.6.32.33-ck2-xioniaredux and I for some odd reason wont get data. It says my network is disabled and I was wondering what I have to do to fix this I even swapped back to stock and it still didnt work plz help.
that rom is about a year old. there are far newer and better roms out there. i suggest reading all the sticky threads and look up yourmom rom or thekraven's cm7 rom if you want something stable with everything working.
Ok but how do I switch back to zvh since my phone is currently zvd?
Switch back to ZVH or upgrade to? Not sure if you were on VH before.
Either way, before trying to upgrade why not give CM7 a try? It works with ZVD which your phone has already.
http://forums.androidcentral.com/lg...rt-optimus-s-thekraven-2-7-2012-zvd-only.html
Download the 2-7 version (I prefer barebones), flash it with gapps.
Also read through the steps for the order to follow while flashing.
That's by favorite ROM to day btw :D
To properly switch back to stock you would need stock recovery, there are guides stickied for that. Did you previously have zvh? You may have a rom radio mismatch if you didn't properly downgrade to zvd. You can't just flash a zvd rom on a zvh radio, the radio will remain zvh.
heritagevine08
