Hey guys,
I think I found a way to get our MSL codes and possibly a lot more. I need someone that hasn't changed their MSL code (and already knows what their code is) to follow these instructions so that I can compare their results to mine. Thanks guys!
Those of you that have updated your PRL are aware of the mobile phone tool QPST. There is a program included with it called "Memory Debug." In order to use it, you need to first setup the ports and QPST configuration as you did for the PRL update.
Besides the MSL code, I am working on other goodies we can extract from this dump. You may be interested in exploring the file yourself.
Update:
Interesting find number one, your google account password is in plain text (unencrypted) in this dump.
Update:
I changed my account password. My phone then prompted for my new password. I entered it in. I then synced my contacts, rebooted, and then dumped the contents of my phone. My new password was in there in plain text twice. The old password was still there too. Something is logging my internet traffic or my keyboard inputs.
- Run the "Memory Debug" program.
- With your phone connected via USB and selected via the "Browse" button, you press "Get Regions".
- This will reboot your phone into "Download mode". You will most likely lose the connection to your phone because download mode uses different drivers and possible a different port. Go into device manager -> Ports (COM & LPT) and find your phone's new COM port.
- Go into the QPST configuration and setup the new port.
- Go back to the "Memory Debug" program, browse for your phone again, and select "Get Regions" again.
- This time it will show you a bunch of options. Leave them all checked and select "SaveTo" and pick an empty folder to dumb your phone memory to. This will take up a little over 500 megs.
- It will take a good amount of time to finish (possible 30 min to an hour). I forget exactly how long.
- When it is done, use a hex editor to look inside the file "ebi_cs0.bin"
- Do a text string search for your own personal MSL code.
- Please write down the hex addresses that it is found at and post them here. Here are where they were in my file:
Code:
0162ABCE
01BA6BDC
01BAD018
01BB1FF8
01BB4748
Update:
Update:
