Need help immediately!!!!!!!!!!!
Sprint HTC 4G EVO
3
My HTC-I have the one like my username- doesn't charge. I bought a new charger and a new battery three days ago. The first two days it was doing fine. Then yesterday I noticed that the battery was draining even while charging. I wasn't using the phone during charging time. Yesterday evening the battery was below 5% so I plugged it in and went to bed. This morning when I got up and checked, the battery was dead and not even charging though it was plugged in. Now I plug it in and the thing only charges for a few minutes and then stops. I haven't been able to switch on the phone all day and it's only charging once in a while. I need help REALLY BADLY cuz I need the phone. WHAT can I do?
Please let me know if you have a solution.
There are some great battery apps, but not having any juice prohibits you from downloading any of them. Your best bet is to head to a Sprint store (or a friend's house, if they also have an EVO) and swap batteries. Plug in and charge up with a different charger as well. This way you can eliminate the battery and/or the charger. Your device might just be dead, unfortunately. If you do get power and can download a battery app, here are two good ones that will give you lots of info, including usage statistics, battery temp, charge current, etc.:
Battery Monitor Widget
GSam Battery Monitor
Jon OapostraphyBrien
