need help in launcher pro
an_icon
74
I want to change the way a file icon looks how can i do this? any help would be great.
Im not sure what you mean by the file icon. If its on the bottom dock just long press and select change icon.
If you're referring to the actual icon you put on the screens then when you add the icon it gives you a small screen and says tap to change under the icon. Now as far as what they look like is up to you. You can find loads of icon packs by searching. Hope that helps
focuspc
