need help phone is not going pass HTC quietly brilliant
Shrii Ram
Active member
Jun 24, 2013
35
need help phone is not going pass HTC quietly brilliant. I unlocked rooted the phone tried recovery flash i dunno want happened now I am not able to boot into my home screen all i am able to go to is Hboot fastboot recovery etc screen. By pressing power button and volume down is my phone bricked ?
It shouldn't be. Are you able to get into recovery?
Sent from my Android Revolutionized HTC ONE.
I am able to get to a page where it says unlocked
PRIMOU pvt ship S-on L Hboot-1.18.0000
Hboot
Fast boot
Recovery
Factory reset
Sim lock
Image crc
getting err device not found if i try any commands..
You need to flash a custom recovery, then a ROM you think you might like and flash it though recovery, and then boot back into bootloader and flash the boot.img for that ROM
this is what is get when i try to boot into recovery mode from cmd
I just re read the entire post. Since you are on the HBOOT screen, use the volume keys to navigate to where it says fastboot and press the power button to select it.. now it should say fastboot usb if you are connected to your computer. Once you get to this stage you may flash the recovery
How long have you sat and waited for it to boot.
It takes up to 7 minutes to boot after bootloader unlocked
Abheetha Athukorala
