Need help quickly!
rapzeh
8
I installed Cyanogenmod on my friends S4 mini, but he said that he couldn't sign into Google Play and wanted it "Back To Normal" so I immediately turned off his phone and used Odin to install the Stock ROM. Bad idea. I didn't wipe ANYTHING or clear the cache, I just went straight to download and installed it. Now it goes to the pulsing Samsung Logo, but won't go into recovery, but it DOES go into Download Mode. What can I do?
Next time you will want to make a good backup data set before you try any fundamental changes to a device.
use a pit file + stock firmware and repartition the phone
Hi, How do I do this? I don't want to be too harsh, but I don't know THAT much about flashing etc. I know what Clockworkmod is and stuff, but how do I do the PIT file stuff? Many thanks to ANYONE who can help me do this. You will literally save me.
pit file is used for repartition .
i need your S4 mini details like
colour + memory size 16 or 32 gb
are you using international network ( LTE, T-mobile, bell etc)
current firmware version you are using (4.3, 4.4.2 etc..)
It's in black or like blue-ish. Dark blue. Not the posh stitched version though.
I don't know how big it is. (It's a friends phone)
He's using Vodafone, but it is an international phone.
I believe it's running KitKat Cyanogenmod.
which is the model number
s4 mini comes with many model number like i9192 , i99190 ,LTE - I9195, I9197
Download the pitfile from here
extract it
now in odin click the pit button and add this pit file then click the pda and add the Stock firmware
check the Autoreboot, Repartion , F-rest time
The phone is stuck on the SAMSUNG logo whilst it pulses. Do you reckon with the info I gave you, you could get me the correct stock rom?
The one I flashed is called: I9195XXUBML4_I9195BTUBNA1_I9195XXUBML4_HOME.tar.md5
Sorry for the delay
No issue with the firmware, if the repartition doesn't works, then it is out of my control.
You need to take it to service center
Sorry
Ready to help you
Abheetha Athukorala
