Need Help Restoring ROM
under999
83
3
I was using warm z twopointtwo and I decided to try skyraider 4. I backed up the warmz rom and installed skyradier 4. Well I decide to go back to warm z but my backup will not restore. I get stuck on the white htc droid incrdible screen. Any ideas?
Only thing I can think of is trying to restore again, how long did you wait at the white HTC screen?
1: power down (pull out the battery if you have to) and boot into manual mode (vol down + pwr) then go into recovery
2: Wipe data/Cache
3: Wipe cache
4: wipe dalvik cache (located under advanced)
5: then go into Backups and restore and choose the Restore and pick the warmZ nandroid you made. you will sit on the first screen for a few mins and then the next screen for a bit longer. This should help for you... Keep me posted :)
