Need help uninstalling module/ hard resetting
  • Start date Start date
A
AC Question
Hello all,
I recently installed an Xposed module that was supposed to change the status bar look in some way. I set it to cutter mode, and now my phone is unusable. Whenever my phone starts, com.android.systemui crashes repeatedly and the status bar won't appear. After about 2 seconds, I can't do anything touch related. I'm thinking not being able to use touch is because of the pattern lock loading repeatedly.
Whenever I try to boot into recovery, I get the yellow Verizon triangle.
I have a Verizon Galaxy S3 running 4.4.2, rooted using towelroot.
USB debugging is enabled.
All my files I wanted saved are already backed up to a computer already.
Is there any way I can access stock recovery again, disable the lock screen from computer, or uninstall the module through the computer?
collingsmwale8
