need help with Android TV box
willsp1983
87
I recently got a new TV box and I'm having some issues with it, the mouse doesn't hit the right places, some apps works fine while others had to have the pointer on the edge of the screen to hit a button near the edge, i know it has to do with screen scaling, if i put it on a big TV I have to zoom out as far as possible then the pointer gets further away from where it's supposed to hit, also it says it takes a micro sd card but it doesn't fit, this is the 2nd box I've had, where the SD card doesn't fit, what im hoping for is a app that will help me make my box run more smoothly, my older box I had didn't have any pointer issues, and was able to be used on any size tv my current tv box is a a95x f1
I moved this to the Android TV forum for more specific traffic.
ledgersupport2025
