Need help with buying overseas lg g3
Ritchie b
I want to buy a LG G3 32gb with 3gb ram.
Now in the UK they only have the 2gb ram version and I assume the extra ram from a overseas version would be better or would it?
The question is what version would be best to buy and from what country?
I know Asian lte versions have a TV arial so that's not needed in the UK. Also some version don't have wireless charging on them but I'm not sure which ones. It's not a must have anyway.
Would I have any problems with a overseas LG g3 used in the UK?
Ideally I just want a 3 gb ram version that is exactly the same as the UK 2 gb versions.
Thanks for any advice given on this. Rick
wvalen89
