need help with flash player
wgc19136
11
I am trying to listen to radio stations online on my phone but when I go to listen it says I need flash player 10.0 or higher flash player and gives me a link to download and install 10.3.
Problem is it is already installed on my phone. I have tried uninstalling and reinstalling but no luck.
Any suggestions?
Bill
Have you checked your browser settings to make sure flash is enabled? The other thing I can suggest is to try a radio app like Tunein. It has tons of actual radio stations available to stream. If the stations you're trying to stream are owned by Clear Channel, they have their own app called iheartradio.
Yup you need to enable plug ins on your browser...its in the settings menu.
Sent from my SCH-I500 using Tapatalk
RichardDixon
