- Mar 19, 2011
- 57
- 4
- 0
Ok, so I've been reading, studying and analyzing the root process after buying an optimus S. I found the forum after I did the VD OTA update, ad found the appropriate process. I can't seem to root my phone and get it to stay that way, and was wondering for suggestions. I've made two attempts so far:
Attempt 1:
Force flash V9 with kp500
z4root
install SuperUser
Install Xionia's Clockwork Recovery
LG Mobile Update Tool to VD
After this, I lost my home button, and when attempting to go into recovery, both manually and by adb, it gave me a blank screen, making me think it reverted to the stock v9 recovery somehow, as I have the newer LCD screen. Flash back to VD.
Attempt 2:
Force flash back to VC
Use OCCv2 to root and install Xionia's
LG mobile update to VD
Again, the recovery went back to stock VC/VD and I lost root.
I must be missing something in the process, but I don't want to try it again until maybe I figure it out. I tried using adb to rename the install-recovery.sh file both times as a precaution, but no joy.
Thanks in advance!
EDIT - Also, just to be clear, I plan on flashing a ROM once I can be sure my root is intact and will stay that way. I haven't made the attempt yet because I have been able to keep rooted.
Attempt 1:
z4root
install SuperUser
Attempt 2:
Thanks in advance!
