Need help with stuck notifications
mps1773
4
I got my DX about a week ago. I have had a new voicemail notification stuck in the notifications bar for about half of that time, which I have been ignoring so far while I tried to find a solution. Now I have that and two photo upload notifications stuck there and NO success whatsoever at finding out how to clear these. H E L P !!!! :) They are driving me nuts!
DX froyo rooted with about 400 downloaded apps :)
There's a "button" at the upper right corner of the pull-down notification menu that says "clear all". It will do just that. It isn't there is there are no notifications in the menu.
BTW - you can access notifications directly from the pull-down menu.
PS - If you are serious about having 400 downloaded apps on your X, you are asking for all sorts of problems. They don't all work well together. Conflicts with the native apps and those you add happen frequently. Beware!
I know about the pull down menu and these three notifications are not cleared by that button. Also, when they are the only three up there the button disappears.
Have you tried rebooting
Shut it down
Pull battery...
count to 60 Mississippi...
reinsert battery...
press power buttin count to 20
let it come back up
that might get it taken care of
Lemme know what you find out..
That did not work. The photo upload notifications disappeared a day or two ago after a random reboot but the voicemail notification yet remains after even this latest try.
Power off unit, turn it back on. Then try calling yourself from another phone, leaving a voice mail, then retrieve it and delete it.
Update:
The notification has cleared. There apparently was a conflict between verizon voicemail and google voice. The notification, when selected, took me to gvoice but the voicemail was with verizon. I activated verizon's voicemail app, found the message and cleared it.
I appreciate your help. Thank you.
Jon OapostraphyBrien
