Need help with Wi-Fi toggle
YankeeMike
48
Hey quick question I'm missing the Wi-Fi toggle up top when I pull down.
I see data, screen rotation, airplane mode etc...I thought Wi-Fi was there when I got phone but no?
Sent from my SCH-I605 using Android Central Forums
Personally I don't have your phone but is there a + sign to add toggles if your super desperate do a reset but there will be a way to add it. I have no clue but thought you should least get 1 reply
I don't see an option in mine for Wifi. You can use an app like Notification Toggle to add Wifi toggle to the notification menu.
Sent from my Verizon Samsung Galaxy Note II
VZW never had a toggle for wifi on the N2. They want us using the ongoing notification they put that shows below the toggles. :-\
Mine has an "Ongoing" wifi notification to turn it on. I don't know how to get rid of the ongoing notification. It's always there. I've unchecked look for wifi in the settings.
Long press on the notification and "app info" will come up. Click on it and hit disable. That will temporarily get rid of the notification. It will come back when you get on wifi again.
App info brings up Android System, and disable is grayed out. There is a check box for notifications under that but it's grayed out too.
Jeniferbrowns
