need help
droodski
16
i had nook color with CM7 Running off SD card, i need to take out android to sell the nook.
I removed the SD card thinking that was the only thing needed to do. Now my nook wont charge.. stuck on low battery screen wait 15 minutes.
Do i need to un mount the sd card or something? or should it work right off the bat as stock?
thanks
Andacar
