Need Help
DMoney1967
3
Just upgraded from a rooted Froyo Kernel running Rubix, to Gingerbread .605. Now I need to know if there are any ROMs that run on the Gingerbread Kernel that are stable and well worked out like rubix was on Froyo?
Any help would be awesome
Tyvm
Any real reason you care which kernel it's running? The kernel is just a kernel, while we often refer to it as Gingerbread or Froyo you can run Gingerbread on the Froyo kernel and probably Froyo on the GB kernel (although I doubt anyone's actually tried). Admittedly there are bugfixes from kernel to kernel, including some security fixes, but most of these won't impact the end user.
There are plenty of good GB-based ROMs out there. You can check out the ROMs forum for some suggestions:
http://forums.androidcentral.com/motorola-x-rooting-roms-hacks/
Liberty Gingerbread seems stable, but I don't know your definition of well worked out.
I am just assuming here since I haven't been stock in forever, that any GB ROM's available are going to be builds that are basically betas. Always being worked on, being released etc. Yet the ones that are released such as that Liberty JD mentioned, and the one alot of us run, MIUI are stable yet will have a bug or two. And if Moto is releasing 120MB stock ROM fixes for the keyboard alone, I would say stock and custom arent that much different these days. Try things out see which one best suits you. Roam the forums and Google til you're ROM'd out, that will be the one u stick with.
I am running Shuji 2.0. I am really liking it. It isn't fancy, but it is quick, has incredible battery life, and enough customizations to be interesting. There are only a couple little bugs that don't really bother me at all.
IndyJones1023
