Need help
Pcorpus21
I had rooted my phone then unrooted it after some months. Now that I'm trying to root it again, it says I'm in soff, however I'm not properly rooted.... Need help
are you running the newest version of Gingerbread?. If so, there is another method you have to use....I unfortunately don't know where to locate it, but search the threads to find out. You can always find a 605.5 version of GINGERBREAD and flash to that (will wipe all your data on the phone...not SD card) and that will take it back to factory.
If you are running a older version of Gingerbread, then you can just use the REVOLUTIONARY method
PmGs
