Need help
wess580
279
5
18
Today I installed the 4.1.2 update and was wandering if it a bug or im just not seeing it but before the updat I was able to disabke the keyboard sound but now I cant can someone help the sound annoying
I did that I even clicked and unclicked the problem is still there
Go to setting>language and input>then go to the settings of whatever keyboard you are using and it will be under there somewhere.
Sent from my SPH-L710 using Tapatalk 2
@meyerweb Keytones is for dialing not the keyboard.
Thanks guys but ive tried all of those already the only thing that works is turning off the system sounds but by doing that I get no alarm sound
I just did the 3mb update and now its off thank for the suggestions everybody
When I woke up this morning it was already downloaded I just had to install it
bohanvo2
