need help
  • Start date Start date
A
AC Question
This is an odd story. I left my galaxy player 5.0 on top of a car. Someone went to the store and apparently it was still on there. It was left in a horrible rainstorm on the side of the road after having dropped with the screen not breaking at all. My grandparents found it the next day! It turned on but i turned it immediately back off and put it in rice for twenty four hours. I took it out and it looked like the charging hole had corroded. I took a tootbrush and brushed it out and it was totally clean. It turned on and i put it on the charger but it wont charge. I put it back in rice to see if there was any moisture left and im gonna let it sit. Anyone know anything that might work or anything i can do?
Do you have insurance for the device. Sounds like the only way you can save yourself. Seriously, the insurance is worth it's weight in hold.
Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
Unfortunately, no. Between the shock and water, it would be difficult to fix, due to multiple causes of failure.
From a Carbon M8 and AC Forums app
Hi there.
You might have to send it to a repair center if you can't get it to work.
KidColoringPage
