Need help!
joey132
223
5
im rooting my phone and im almost done with all the prompt screen crap. i just need someone to help me to get through the prompts and i should be able to find my way through the common sense stuff and easy to follow steps.
i just can't get my head around this stuff. im almost done and am on step 9 at the part were it say..
9. Backup your 4G RSA keys (in command prompt, at the #) ? The following three commands will create this directory: nandroid/RSA-PR-BACKUP on your sdcard, inside of that directory will be this file: wimax.img, that file is a digital image of the partition on your phone which holds your 4G keys.
Quote:
mkdir /sdcard/nandroid
mkdir /sdcard/nandroid/RSA-PR-BACKUP
cat /dev/mtd/mtd0 > /sdcard/nandroid/RSA-PR-BACKUP/wimax.img
You type that in Android terminal.
Not that important though. You can just do a nandroid and they will be backed up. Both ClockworkMod and Amon_Ra backup your entire wimax partition.
To do that: Power off your phone, hold down power and vol+down, backup.
Reactions: joey132
lol im so sorry but idk what you just said lmfao what is a android terminal
like i said i don't understand all these prompts once i get to all the manual stuff with the phone i can go on from their
