Need Help.
under999
83
3
I was using warm z twopointtwo and I decided to try skyraider 4. I backed up the warmz rom and installed skyradier 4. Well I decide to go back to warm z but my backup will not restore. I get stuck on the white htc droid incrdible screen. Any ideas?
Were there any error messages when you did the restore? Warm Z can be tricky. Try clearing data, cache and dalvik twice each before running your nandroid again. Also chack for any error messages during the nandroid restore.
Ok i will clear both a few times and then look for an error. I am also using Clockworkmod 3.0.08.
also when i restore there is no error message. it doesnt to take as long as a full back should take
yes but this is my wifes phone and she wants the warm z nandroid. I wonder if rom manager did not fully backup the nandroid?
Are you restoring the nandroid in ROM manager or in Recovery? If you are restoring in ROM manager, try doing it in recovery.
If it's running really fast and not giving any errors, you likely have a bad nandroid. Either re-flash warm Z or restore to an earlier nandroid.
Sorry.
liquidsnake757
