Need measurement from 3500 battery
zrxoa1
1,403
44
Can someone with the Seidio 3500 mAh battery measure it and tell me how thick it is. Not in the phone, but the thickness of the battery itself.
Thanks!
I can do this for you. What are you needing it for?
I didn't measure mine personally but here are the measurements off of Amazon.
4.5 x 0.5 x 2.5 inches ; 4.3 ounces
I didnt even think about amazon!
I just wondered how it compared to my 2600 mAh battery from ebay...
Thank u for the info!
No problem. It doesn't make it much thicker than the stock battery honestly. When you feel it in your hand. I was sketchy on getting one at first but SO glad I did. When I installed it I was like wow this is nothing like I thought it would be. And it's well worth it. You can go days on the thing.
I got one of the 3500 ones off ebay with the thick battery cover will post results after a few days. I have question as to the thickness. I like the holster style cases has anyone found one that will accomadate the thicker phone?
Well, I have a holster on mine that is from one of the hardshell cases. The back will not fit on it anymore obviously because the phone is thicker. It's one that molds around the phone. But the front part that slides over it fits perfect and actually grips the new back so I can use it as a holster and it's tightly fitted so the phone will not slip out. It's one they sell at the verizon store.
Rick,
If you are still out there, can you tell me how thick that 3500 battery is? I have one each of the e bay 2600 and 3000 batteries but my 2600 ias starting to not charge 100% and die sooner. I thought of getting two of the 3500 ebay units but was unsure of they would fit under my existing back. It is double humped not just thick like the other covers...
Rick,
Yeah I still have it and it is working fine, As for the cover it makes my phone .71" thick (just measured it with a caliper :D ) hope this helps.
Thank you. One more favor? If you get a chance, can you measure just the battery itself? My 2600 and 3000 look to be about .370". The 3500s are about the same I think, but would like to see it verified.
Appreciate the info! Thank you.
Jeez you are a pain J/K:p Mine measures .340" keep in mine it is one of those no name Chinese Specials
Not sure if I am allowed to post a link but here is the ebay seller I got it from: 3500MAH EXTENDED BATTERY+ COVER FOR HTC DROID INCREDIBL | eBay
Prince08900
