Need Quick Help- Forgot how to get into recovery menu
TVCMI
48
I was using the new GB leak and decided to flash the odexed version. I got into bootloops I could not get out of, no matter how many battery pulls and factory resets I did. So I sbf'd back to stock 2.3.340 and again bootloop. I went into recovery to factory reset, pressed the power/home button and get to the android/triangle. But it's been so long since I have gone into stock recovery that I can't seem to get into the menu. Is it hold power/search or just search? I can't seem to get in either way?? I am laughing at myself right now:D
Gingerbread recovery is different. Once at the android Guy and exclamation point you have to hold both volume buttons to enter recovery. Not search button. That's froyo.
And use the Power button to select instead of the camera button.
Technics1124
