Need Serious Clockwork help
318sugarhill
615
20
I've been trying to restore/install froyo/ do anything I can but no matter what zip file I download Clockwork tells me
--Installing: /sdcard/#######
Finding update package...
Opening update package...
Installing update...
Installation aborted.
That's all I get. No error, no bad, nothing. It doesn't matter if it's the restore files or the partition boot with stock zip, or the froyo zip. Nothing works. The only thing the Nook can do is load an SD card Rom, but that is very slow.
I've tried using the trick from SD froyo and installing CWR and I've tried booting an SD with the CWR image. Both are doing exactly the same thing.
Any help would be greatly appreciated.
Just an FYI, I solved my problem, and NO OTHER solutions were working.
This is the link for my savior!
Nook Color: Recover Any Bricked Device | Maurice Mongeon
I used the quick easy method by burning the image to an SD card (follow the instructions on creating a froyo sd card for burning an SD card image)
This method worked as advertised. It was easy, brought my Nook back from the black screen of death, and was a relief. I'll post this so anyone else who borks their device can return to a nook fresh out of the box. This returned my nook to stock unrooted 1.0.1
Casperxx99
