Netflix 1.3 Works!?!?
Im running CM7(ath3nos) @ 729mhz, I installed the APK where the guy (forget who it was, its on this forum though I believe) themed it to be green instead of red. I flashed no other zips or anything and have watched both over 3G and Wifi, multiple TV episodes and they all play clearly, no lines, no syncing problems either. onyl problem is when first opened and when getting back to the menu from watching something it always asks if I want to upgrade to the newer version and I just keep saying no.
You can get the newestt official app by using the flashable zips in my signature (if you are rooted) and no more annoying message. :)
For now use ath3nos cm7 instructions and I'll make you guys an update to reflect the current drew build soon enough. :)
I got netflix 1.3 and I have the sync issues I am on the drew build with the collin_ph battery hack even overclocked. However version 1.2.2 works perfectly clocked at stock 600mhz (boy does that make my old Dell Latitude CPxJ feel inadequate)
I think the issue is that you are not using the official versions with my zips. You are using the hacked versions from whatever link. Follow the instructions in my thread for ath3nos cm7 and download thee official then report back to us. :)
EDIT: Also under cyanogenmod settings change the governer from smartass to ondemand. Smartass seems to cause a sync/lag issue on cm7.
ok I overclocked to 748mhz using setcpu and it runs good just sometimes it seems like it loses sync and has to catch up.
The prior version of Netflix, 1.2 worked also. With or without root. That is the version they stopped checking what device it was playing on. BUt I always had a green line on the top of the video. Does this 1.3 have the green line that 1.2 had?
never had the green line when i was running cm7....
with 1.2.something
oliver11
