Netflix problem on MK808B Android 4.2.2
Eric Klassen
I am running the MK808B with Android 4.2.2 on an LG HDTV. Netflix will load (I've tried the version from the play store and a "black" version that is supposed to work on all Android devices. All results are the same. I get into the catalogue fine but when the movie plays the image is scrambled. The audio is fine but the image seems like I am missing a codec or something.Anyone have this problem with other devices? How can I get Netflix to work normally?
Hi Kevin, do you know how to install this, when I try to install it say APP not found,thanks.
I had the same problem but as you said keeps pausing and stop ...there something wrong with our mk808b or with the 4.22?!
Same here. Just received my mk808b yesterday. Downloaded Netflix but the video displayed is scrambled. Tried the link with the older build of Netflix but that freezes and locks up while streaming. Any help would be greatly appreciated.
Ok I found a solution to the problem!
Changed to 4.1.1 stock ROM and no more any problem, works perfect without pause stop or scramble image...
got my mk808b same issue with 4.2.2 OS with netflix. You said you have change to 4.1.1 stock ROM. Can you provide the links and instructions would be great.
Hi Kevin, you know how do I change the android 4.2.2 to 4.1.1, since netflix keeps crashing and gave an error 13001, and stopped working. thank you
fidsomedia
