Netflix problem
Serial Fordicator
501
16
I purchased a 16 gb transformer on the bb black friday sale. I have also purchased the keyboard dock and am using it. I have it tethered through wifi to my droid razr. When I click on the netflix app, it says Netflix is trying to connect to the availible network, and asks me to connect or exit and will not connect. I have cleared the data and everything. I have gotten it to work a few times, but for the most part, it wont connect.
This is going to sound like snark but - if netflix works on normal wifi and not on the Razr hotspot - and you are acknowledging that it is an issue with that handset - I would think you should troubleshoot it on the Razr forum?
I don't have access to other WiFi. I am away from home. I assume its the razr hotspot, but posted here in case anyoneelse was noticing the same on their Asus on different WiFi.
O don't have any issues accessing Netflix on different wifi connection and I use a bunch including my Thunderbolt. I would trouble shoot the Razr if I were you.
The razr has had issues regarding the mobile hotspot and won't access certain websites.
That is not as much a known issue as it is a carrier regulation. With some carriers that allow tethering also have invested effort to limit access to high bandwidth websites. So customers don't burn through their 5gb in less than a few days.
It isn't carrier, it's an mtu issue on the razr. All razr's have this issue. Bionic hotspot will open any website.
CHirsRoot
