Network mode option does not have my verizon S7 edge
  • Start date Start date
A
AC Question
Network mode option does not have and I can't choose 4G lte on my verizon S7 edge(1 sim).In my mobile network setting,just 4 options(Data roaming access,roaming,signal strength and access point name) have existed.How to fix it.
It sounds like you're not going far enough. Tap on NETWORK MODE.
Your choices should be GLOBAL, LTE/CDMA, and LTE/GSM/UMTS. For use here in the US, keep it set to either GLOBAL or LTE/CDMA. Both should be able to access a 4G/LTE network.
