Neuxs 6 ota question
I do that for whatever apps support it like Podcast Republic and Nova Launcher. As for Googles new 6.0 backup and restore it is still useless as usual. The only app that remembered my settings after the restore was Power Toggles which is good because there is no export backup settings and Greenify. Every other app I had to log in to and reconfigure again.
Google's backup/restore works fine - it just need the app developer to actually use it :) Android won't forcefully backup app data - the app developer has to use the backup API.
Power Toggles actually has an option to backup and restore widget settings - I use that if the widget disappears for some reason. The only one that I struggle with is Google Authenticator - no backup option. Have to rescan the QR codes if I ever had to restore it. I know Authy supports cloud backup - not comfortable handing over 2FA codes to a third party ;)
On an unrelated note, 6.0.1 MMB29K factory images are out. Flashed it a short while ago. Nothing major that I saw (new emojis, and some tweaks to the do-not-disturb setting)
Try picking the radio.img from the 'right' factory image for your carrier. Sadly, Google still doesn't seem to have a unified build across carriers. Grr!
On T-Mo, MRA56K (everything including radio) seems to be working great for me
What I plan on doing. I just gotta find which factory image "belongs" to AT&T.
I flashed 6.0.1 last night and so far so good. I won't truly know until I go out away from home if its good to go on my signal.
williestringfield90
