New Leak!
GPS Signal is very weak with this leak. Looses signal every 5 minutes and takes 2 to reacquire...
GPS works great for me I am on sky ICS right now but it's based off of this leak. It worked just fine a week ago on the stock leak too. I used it when I had to drive to NJ
yeah, must be my phone then... i have to keep it on the dashboard to toast under the sunlight... if i move it from there, it won't work... before i could keep it on the center console or clipped to the a/c vents.
You can to do a complete wipe with CWM and reinstall the leak again. Perhaps something went wrong when you flashed it the first time. Like I said UCLE2 was working perfectly for me except the battery was not that good as I'm getting now with the Sky ICS
araelbenjie
