New Messages will not notify in sound or on homepage!
  • Thread starter Android Central Question
  • Start date
A
Even though my sound option is on as a notification as well as vibrate are chosen.. Shows my messages icon it does not show the number at the bottom indicating new messages were received And my sound does not work when new text messages are received..
How can I fix or when is the next update?? Need Soulution!
(GalaxyS9)
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,943
5,247
113
Welcome to Android Central! Have you also checked the messaging app's notification settings to make sure everything is turned on correctly?
domer
65
I'm also facing the same problem. Message notifications are on, app icon badges are on. The only way to see that I have new messages is by opening the app and then seeing unread messages. The problem for me is intermittent. I do not have a DND period set, and otherwise no restrictions on my messaging app. Help please!
mustang7757
Super Moderator
Moderator
Feb 6, 2017
92,091
6,655
113
Try go into settings>general>reset >reset settings
domer
65
Device is restarting now. I should have mentioned that this started happening on my Note 9 as well. I now have a Note 10 Plus on AT&T. I did not restore via backup when I got the Note 10.
domer
65
I've cleared cache memory, but cleared again after your suggestion. No dice. Yesterday notifications started coming in again, but just inexplicably stopped.
domer
65
The problem has been happening on Google Messages as well as stock Samsung app. I'll try deleting Google Messages, and using the stock app again. Thanks again for all of your help and suggestions.
MansiDaware
