New Phone Tips
Hey man I got the T-mobile version, but I can't find the Smart Network is it not on T-mobile or I need to look else where?
Posted via the Android Central App on the Galaxy S6
Did you work out your overheating issue?
Yes I did, I usually have my charger plugged in even when I'M not charging and I decided to unplug after u finish charging and it doesn't overheat and it doesn't charge slow anymore
Great . Glad you got it sorted out.
Wow the plastic cover on the s6 is so tiny you almost couldn't tell it was there. I only could cause you guys told me about it and I could see the bubble
Take all the plastic off, including the one on the camera and LED flash.
Follow the screen prompts and set up your phone.
Long press the homescreen and disable the Briefing tab.
Go to Settings/About Device and tap the build number seven times and change animations to 0.5x
In Applications, disable bloat and other applications.
in Notifications, only select those you want.
In Google app in Settings, disable the synchronization options you don't want.
Go through the rest of the Settings Menus and tweak your device.
Give TouchWiz at least a week before you get a third party launcher. Totally optional suggestion as you may prefer another launcher.
Turn screen brightness to 50% and use auto brightness only in direct sunlight.
Use location only when needed. Make sure GPS only option is selected.
Use Adaptive Display in the Display options.
Do some, all. Or none of the above as device setup depends upon preferences.
Welcome to the GS6. Hope you enjoy it. Hit us back with your feedback.
Where do I go to change the animations?
EDIT: never mind I found it
In the Camera, swipe left to see the picture you just took. Swipe right for Options/controls.
alejandro109322
