nexsus 5 galary problem
hemant kumar5
3
hi friends i bought my nexsus 5 phone last week , i really liked it since yesterday i cant able to open galary it says no external storage available i dont know how to fix can you guys help me out with this.
Welcome to the forums.
That is strange. Try a factory reset. If that doesn't work, I would contact Google about this and on how to do a return.
hi thank you , i had already done factory reset but still again i am facing same problem
Does the issue happen with the Gallery App only or other Apps as well? For example, open the Photo App and see if your photos are there.
If still nothing then I'd also suggest contacting Google for a replacement. If you are savvy enough to try a restore on your own oergaps that would help.
