Nexus 10. Advanced MIMO WiFi
Shilohcane
1,308
On the Google play store it says about the Nexus 10;
"Browse the web with the speed of Chrome. Updated to bring you the web in HD, Chrome is now better than ever on Nexus 10. Advanced MIMO WiFi and accelerated page loading give you web browsing speeds up to 4x faster* than normal WiFi."
How does that work better than my current Wi-Fi that is a 802.11n I don't think it is MIMO?
Multiple in Multiple out. I assume that juust means more antenna to send and receive. Most routers are at least dual band n. ie support 150mbsx2 for 300mbps. I have a 450 one myself, that supports 3 antenna so hopefully the nexus 10 will too. Although I doubt it because the majority of routers are dual band.
Ishimwe
